Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Primer coating on new body panels
Old 04-27-2011, 07:50 AM
freethinker52 freethinker52 is offline
Originally Posted by desertdave
I purchased some new body panels for my mustang and was curious about the black primer they applied to the panels. Should I strip this all off so I can apply my self-etching primer, or should I apply the self-etching primer right over the black primer. Or do I skip the self-etching primer all together on these new panels.
etchimg primer should only be used on bare metal if at all. i would use epoxy instead. if the black coating will pass these tests i leave it on. laqure will not remove it and if it will feather nicely. if not strip it off. the instructions from the panel manufacturer that i use is to rough it and prime over it.
