Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Primer coating on new body panels
Old 04-27-2011, 08:30 PM
freethinker52 freethinker52 is offline
Originally Posted by desertdave
Well my plan of attack was to use the DuPont VariPrime self etching primer as my first coat, then to use the Nason 2K Urethane high build primer, and finally a one of the DuPont 2k sealers. Not sure which one yet, but thats my process I will be using.
I will try the lacquer thinner trick to see if these panels are E-coated or not. I'm getting my panels from CJ Pony Parts out of NJ. Thanks for the advice.
i would use this instead:
NASON® FUL-POXY® 491-16™ EPOXY PRIMER
then this:
NASON® SELECTPRIME™ 421-19TM (GRAY)
2K URETHANE PRIMER
