Primer color - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2012, 12:15 PM
K72Nova's Avatar
Primer color
So I did a little research and couldn’t come up with exactly what I was looking for, I plan on stripping the car to bare metal, epoxy primer, body filler, 2k primer, bc/cc in an almost royal blue (I don’t have the paint code at work with me). I have been told that you want your primer that’s just under your basecoat to be as close as possible to your basecoat color, so in my case this would be black, I was hoping to do my epoxy primer in black because I was thinking it would be easier to see the imperfections that I am trying to fix, I’m new to bodywork so I’m wondering what you guys are doing to make it easier to see those imperfections, I’m assuming I don’t want to spray black epoxy and then try to spray black 2k on top of that?
Another question is that I have been told to spray epoxy primer and then do body filler over the epoxy, can I also do body filler first and then epoxy, or will there be issues with the epoxy sticking to the filler? This question is a bit vague without all the details but for a rough guestimate, how many gallons of epoxy primer would I need to cover all body panels, the interior, and the underside of a 72 Nova? The primer I will be using is a 2 part 1:1. Again sorry if I’m a bit vague on this as I haven’t done much bodywork, I do plan on doing a lot of practice on spare panels I have laying around before I attempt to tackle my car.
Old 08-25-2012, 01:39 PM
67Elcamino's Avatar
I liked using black Epoxy under filler or gray primer because when Im sanding and blocking if I start seeing black showing through I know its a high spot and know when to stop. I personally noticed if I shot a couple of good coats of epoxy it would save me the headache of accidentally sanding through the epoxy and exposing bare metal again.
Once I had the metal, filler, and primer pretty straight then I went to the guide coat etc for final blocking
Old 08-25-2012, 01:44 PM
67Elcamino's Avatar
FYI test a small panel with the Royal blue under black then Royal blue over gray primer. I think you be happier with it over gray? but..... might be harder to shoot without tiger striping etc... than it would be over black? Just my opinion Im not very experience in full paint jobs and diffrent colors etc
Old 08-25-2012, 01:58 PM
K72Nova's Avatar
yea that's a good idea, I guess I'll have to do a bit of experimenting and see what works best, I guess if the black works out better I could do black epoxy, gray 2k, black guide coat.
Old 08-25-2012, 03:55 PM
rusthater89's Avatar
If you are spraying blue paint you should use a gray primer. I'm not sure why, It's one of the many things I heard other experienced people tell me.
Old 08-27-2012, 10:03 AM
K72Nova's Avatar
Good to know, Thanks!
primer color hinges56 Body - Exterior 2 05-13-2012 11:14 AM
what color primer cornfieldcars Body - Exterior 17 07-27-2009 07:26 PM
primer color? holeshot92 Body - Exterior 2 01-16-2009 12:38 PM
A test on primer color vs SOLID base color outcome Bee4Me Body - Exterior 9 10-14-2008 11:42 AM
color of the primer Rodrunner Body - Exterior 10 01-22-2004 11:16 PM
