Primer filling?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2003, 06:15 PM
ChrisMiddleron's Avatar
Primer filling??
Hey peoples im far away from priming my car, but for very small imperfections that the hand can feel slightly its an ok idea to put the primer on thick and sand it smooth right?
Old 08-26-2003, 06:31 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Use a glazing putty, urethane with a catalyst. If you get the primer to heavy or thick, trying to fill with it you will have shrinkage. he primer is used only to fill course sandpaper scratches and level repaired places so they will blend with the level of the surrounding material.
Any thing you can feel, or see should be leveled with a filler of some kind, then primed heavy and blocked or long boarded. HTH.
Good Luck
Troy
