Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - primer job
Thread: primer job
Old 09-14-2008, 07:41 AM
RODDER18's Avatar
RODDER18 RODDER18 is offline
Use an epoxy primer. Filler primers will absorb moisture and may not stick to bare metal. Epoxy primers are used over metal surfaces and seal it until you are ready to paint. It will fade as primers do not have UV protection and will also have to be sanded before top coating if not painted within the recommended time frame.
