-   -   Primer mobile (http://www.hotrodders.com/forum/primer-mobile-25675.html)
Error404 10-13-2003 01:12 PM
Primer mobile
I have been using rattle can primer on my camaro whiel I finish up the body work, but now I would like to keep it all primer.
The problem, is that primer seems to get stained and scratched really easy. Is there any special type of primer that is stronger?
I just want the dull grey look (like the flat black hotrods, only grey)
A friend of mine has a paint gun, and said he would shoot it for me, so it will look better than rattle cans :-)
someone told me that epoxy primer would do the trick. is this correct?
Thanks so much!
Daniel
jwart 10-13-2003 01:30 PM
i like flat black myself. epoxy primer has to be top coated to seal & uv protection. you can clear it with flattening agent for the dull look, but from same manufacture your primer is from. jwart
302 Z28 10-13-2003 02:40 PM
You will need to remove all the "rattle can" primer before you shoot the whole car with REAL primer, if you expect the REAL primer to hold.
Vince
Error404 10-13-2003 06:25 PM
everything accept the front bumper cover and passenger fender were sanded down and sprayed with "real" primer, I'm just not sure what type it was :-\
but for the fender and nose cover, sand it all the way down to metal and urethane?
this flattening agent, is it something that will be shot on to the car by it self, or does that mix with something?
302 Z28 10-13-2003 06:38 PM
deleted
Kevin45 10-14-2003 05:54 AM
Well what is it? Rattle can or real? If you spray primer from a quart can that has been purchased from a paint jobber over a rattle can of primer that has been purchased from WallyWorld or the local discount parts stores you will have trouble later on. Remove all the rattle can primer, get a good brand name of primer and shoot the whole car. Then you can coat with clear that has a flattening agent put in. Or you can get any color and have a flattening agent combined with it. Also check this out for a factory tinted primer Click the mouse here
Kevin
Error404 10-14-2003 10:22 AM
sorry for the confusion. the car has been primered a while ago (from a spray gun), but I have done quite a bit of body work on the nose piece, and just used rattle can to make it look halfway decent.
So basicly, just add the flattening agent to whatever goes on top? Which would be stronger, clear with the flattening, or paint with the flattening? I want something that won't stain or scratch easy. I assume that the clear woudl be stronger, because thats usualy the last coat on the car, right?
http://www.danielbuck.net/wip/nose11.jpg
