Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - primer orange peel help
Old 10-25-2004, 09:16 PM
jerrylo jerrylo is offline
New Member
Finishline is made by devilbiss. I got my original settings from the manual and it says the inlet pressure should be 23 psi and have an air flow of 13 scfm which will give you a cap pressure of 10 psi. I just bought a new ingersol 60 gal. 2 stage compressor so I know that air flow is not the problem, it is just me learning how to properly set it. The pressure did seem low to me, but this is my first time using a hvlp gun. I will sure try raising the pressure to get rid of the orange peel. I got most of it blocked off yesterday and I do not feel like doing that again. Do any of you measure the pressure at the aircap?
