should i wipe the primer down between coats[say with prepsall or similar]i have been wiping with prepsall then priming then sanding then wipe with prepsall then sandind etc.it seems to me that the prepsall melts the primer a tiny bit so that when you wipe and it dries you can see a faint haze.i'm wondering if this is a problem?thanks for your help!jimm
jwcn45, howdy! thanks for your advice! hope ican help you or others at the right time,jimm
Ya , prepsol should be used first , to help lift any contaminants before you start. I may use it again is if you have a car that has been severly undercoated or oiled and you can see the oils bleeding into the primer, or you are sure that there has been a contaminant on the surface of the primer ( oil spray, oily hands, armourall or wax contact). Sometimes this will happen if the car sits in primer for an extended period of time.
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 127 | 08-26-2012 03:07 AM |
| Primer Questions & observations | x711 | Body - Exterior | 1 | 01-19-2006 09:23 PM |
| metal prep and epoxy primer? | 62galaxiguy | Body - Exterior | 6 | 05-16-2005 07:02 PM |
| Prep after chemical strip, before primer? | GMW | Body - Exterior | 6 | 12-08-2004 06:02 AM |
| weld thu primer prep | oldred | Body - Exterior | 9 | 10-14-2004 07:13 AM |
