Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - primer prep
Thread: primer prep
Old 04-08-2002, 12:02 PM
jimm jimm is offline
Post primer prep
should i wipe the primer down between coats[say with prepsall or similar]i have been wiping with prepsall then priming then sanding then wipe with prepsall then sandind seems to me that the prepsall melts the primer a tiny bit so that when you wipe and it dries you can see a faint haze.i'm wondering if this is a problem?thanks for your help!jimm
