Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - primer prep
Thread: primer prep
Old 04-08-2002, 03:10 PM
jwcnj45's Avatar
jwcnj45 jwcnj45 is offline
Wiping your primer down with prep sol is not necessary. Prep sol the panel before priming. If you want to you could use a tack cloth between coats of primer. Just make sure the primer has flashed off first before you tack it off.
