primer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2009, 11:58 AM
72 grabber 51F-1 65 chevystang
primer question
I am doing body work on my maverick. There are some areas that I am having to sand to bare metal. I was wondering if there was any spray can primer that I could use to stop rust from coming back. I have seen the automobile primer at walmart and was wondering if it was any good
Old 09-26-2009, 01:09 PM
BOBCRMAN@aol.com's Avatar
Most of the spray can "sand-able" primers are porous and absorb and hold water=rust.
Old 09-26-2009, 01:33 PM
nope, not really. Most of the spray can primers on the hardware shelf are going to be lacquer based primer, and will provide practically no protection.
You really need a 2 part epoxy, and that doesn't come in a spray can, or found on a walmart shelf. Well they do make an epoxy in a spray can, links have been posted on here in the past to various manufacturers of it, but is aweful pricey for the amount you would get, and would have to use it all up at once I believe, since once opened you only have limited pot life before it hardens being activated.
How large are these spots. Some possibilitys if you don't have access to a spray gun and compressor for smaller spots to get them protected is to use a preval sprayer to apply the mixed epoxy,(available at harbor freight for about 5 bucks) or to brush it on, allowing it plenty of time to flash since you will have a lot of solvent buildup brush applied. They also have refillable aerosol cans at harbor freight, though I've never tried one being as I've always had a compressor. Or maybe a refillable air tank (fill tank at the gas station) would be able to power a small touchup gun with very modest air requirements, enough to do a small spot or two. I have used an airtank limitedly with an airbrush and it sprayed.
All of these probably wouldn't lay down the greatest and would probably require a bit of sanding to level out and wouldn't work well for a very large area. But where there is a will there is a way.
If you don't have a compressor, and really plan to do any amount of bodywork, a compressor and a decent spray gun the compressor is able to power, is one of the first investments you should make, the best you can afford. It will soon pay for itself. The ability to run some power tools can really save time, and paint and bodywork is time consuming enough as it is. And the best activated materials to produce a long lasting job require a spray gun and compressor to be applied well.
Kinda dig those Mavericks, I hardly ever see any around these parts.
Old 09-26-2009, 02:00 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
There are newer 2-part epoxy primers in spray cans. The activator is released into the primer by inserting a plunger into a stem on the bottom of the spray can. As kenseth17 mentioned, they are expensive, and have a limited pot life.
See this wiki article for more details: Epoxy primer.
Also, see this thread: Solvent resistant real 2k epoxy aerosol can.
Old 09-26-2009, 03:24 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
They make a spray can wash prime that will help a lot on rust coming thru. After a 5 mn dry you can prime with a spray can primer. Not as good as priming with a 2k and a gun but will work.
Old 09-26-2009, 06:24 PM
I have a compressor and gun but wanted to go the easy way I suppose. I plan on priming the whole car next week with real primer. I really don't want to do the bodywork again
Old 09-26-2009, 08:41 PM
302 Z28's Avatar
The only solution you have is to keep the car indoors in a dry environment while you are working on it to prevent rust. Upon the point to where you are satisfied with your body work apply a couple of heavy wet coats of a quality epoxy primer then follow that with a couple of good coats of 2K primer/surfacer for final block sanding. I WOULD NOT EVEN CONSIDER USING A WASH PRIMER, they cause more problems than they are worth.
And I agree, there are no rattle can primers that are worth a flip, except for the mentioned 2K rattle can primer.
Vince
Old 09-27-2009, 01:01 AM
CMR CMR is offline
0.....55.../100
I had this same question. I'm mainly looking for something I can apply to keep the rust away while I work on my project. I don't mind using a brush or roller for a temp job, but I would like some advice on what to use. Also, what about sprays with rust inhibitors like Rustoleum? Are they worth a crap?
Old 09-27-2009, 07:53 AM
No. Use epoxy. Do youre bodywork panel at a time then epoxy/prime.
Old 09-27-2009, 08:12 AM
302 Z28's Avatar
Advertising hype.
Vince
sand and primer question APACHEMAN Body - Exterior 6 02-18-2009 09:03 PM
Primer Question eagle24 Body - Exterior 1 12-20-2005 03:11 PM
spri primer shipping question, clear gooo on containers pigman Body - Exterior 8 08-23-2005 10:32 AM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
Quickie primer question Bluepen Body - Exterior 1 05-21-2003 05:33 PM
