primer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2006, 09:17 PM
1969 Camaro owner
primer question
I have some rust primer in spray cans that I want to use on a prepped surface of metal/oem primer/filler. I plan on using this primer once my body work is done, letting it cure then when I can get it to a paint booth, sand using 400 grit then use an epoxy primer then bc/cc. Will this method work without causing problems provided I do everything right?
Old 04-28-2006, 04:52 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I wouldn't use the rattle can primer for any prep work, if you do,
make sure you get it all sanded off before primeing and painting.
It's adhesion is low and protection is practiically nothing.
The rattle can primer I've seen is lacquer base, it doesn't keep moisture
from going through. Lacquer base primers shouldn't be wet sanded for
that reason. It may look good on the outside but underneath the metal
will rust fairly quick.
Old 04-28-2006, 05:59 AM
302 Z28's Avatar
Anything from a rattle can should not be under any paint job that you expect to last. Remove all of it before you apply a catalyzed primer and paint.
Vince
Old 04-28-2006, 07:44 AM
roger1's Avatar
Not a good idea. You will just be causing yourself more work to take off that primer later.
Just hit it with a coat of epoxy now and then when it's ready for paint, sand it to scuff it up and put on another coat of epoxy primer before primer/surfacer and painting.
« chrome $ | rust »
sand and primer question APACHEMAN Body - Exterior 6 02-18-2009 09:03 PM
Primer Question eagle24 Body - Exterior 1 12-20-2005 03:11 PM
spri primer shipping question, clear gooo on containers pigman Body - Exterior 8 08-23-2005 10:32 AM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
Quickie primer question Bluepen Body - Exterior 1 05-21-2003 05:33 PM
