Primer Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2008, 05:44 PM
Primer Questions
My 2K HS primer was applied over the epoxy then blocked in 180grit dry, reapplied HS primer then blocked 400 grit wet about 6 weeks ago.
Been preparing other panels since.
I have been doing the above priming and blocking but have noticed the original stuff isnít as smooth to touch as the recent panels.
Is this normal?
Should I resand before appling the next coat of primer?
Could the roughness be over spray?
I here you should let the primer sit for a month prior to final sanding for top coat to allow for shrinkage etc?
I am planning on finishing in 600wet?
Thanks
Old 01-06-2008, 06:26 PM
302 Z28's Avatar
It's possible the primer has shrunken a little and that is what your seeing. If you are going to do a final sand with 600 I would not worry about it.
Vince
Questions about Evercoat Feather Fill primer. Fordy8man Body - Exterior 16 02-05-2010 01:33 PM
Primer & other questions. MadDAWG Body - Exterior 1 12-05-2007 06:04 AM
more primer questions boxcar Body - Exterior 2 10-20-2007 02:44 PM
Primer Questions & observations x711 Body - Exterior 1 01-19-2006 10:23 PM
Primer hardener - sold it to me, but not on tech sheet? 58Apache Body - Exterior 5 10-15-2005 05:02 PM
