-   -   primer questions (http://www.hotrodders.com/forum/primer-questions-218901.html)
aarias-31 05-02-2012 07:53 AM
primer questions
Need some help on spraying primer. Can I use a 1.3 or 1.4mm nozzle tip to spray epoxy primer and 2k primer?
John long 05-02-2012 08:13 AM
I don't think you will be pleased with the results. a 1.8 nozzle is recommended do to the high viscosity of the primers. Hard to get a good wet high build with a finish gun.
swvalcon 05-02-2012 10:45 AM
You can make it work. Open your gun mixture all the way up and reduce both your epoxy and your 2-k primers. Just be sure to put on and extra coat of two.
johnyIROC 05-02-2012 07:55 PM
I've done high-build polyester with 1.4 and no issues.
deadbodyman 05-06-2012 07:24 AM
Do yourself a favor
Go to your local lumber store and get a 40.00 gun with at least a 1.5 tip, 1.8 if you can find one...the right tool for the job...
