primer questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2012, 06:53 AM
primer questions
Need some help on spraying primer. Can I use a 1.3 or 1.4mm nozzle tip to spray epoxy primer and 2k primer?
Old 05-02-2012, 07:13 AM
I don't think you will be pleased with the results. a 1.8 nozzle is recommended do to the high viscosity of the primers. Hard to get a good wet high build with a finish gun.
Old 05-02-2012, 09:45 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
You can make it work. Open your gun mixture all the way up and reduce both your epoxy and your 2-k primers. Just be sure to put on and extra coat of two.
Old 05-02-2012, 06:55 PM
Last journal entry: G8 GT 2
I've done high-build polyester with 1.4 and no issues.
Old 05-06-2012, 06:24 AM
deadbodyman's Avatar
Wiki Edits: 11
Do yourself a favor
Go to your local lumber store and get a 40.00 gun with at least a 1.5 tip, 1.8 if you can find one...the right tool for the job...
Primer Questions iFlip Body - Exterior 8 06-25-2010 09:24 AM
Primer Questions northiam Body - Exterior 1 01-06-2008 05:26 PM
more primer questions boxcar Body - Exterior 2 10-20-2007 01:44 PM
more primer questions! GEARHEADWV Body - Exterior 5 02-28-2007 05:49 AM
Different primer questions Blazin88 Body - Exterior 10 08-02-2004 07:50 AM
