Primer Questions & observations - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2006, 08:44 PM
X711
First my observations on primer and then a couple of general questions.
Looking at the various information about primer I have noticed one constant
that is typical of most posts. People that use a epoxy based primer direct to metal or over a scuffed substrate typically cover it with a 2k based primer and in some cases a sealer after the 2k primer.
So we would have a typical Layer build as follows.
1 Metal substrate or scuffed paint
2 Epoxy Primer
3 2k primer.
4 Thin Sealer coat "Sometime"
Ok to my questions.
1 Why do most people surface the epoxy based primer with a 2K based
primer.
2 Is the sealer coat used to provide "only" a very smooth finish to paint on,
or does it inhibit moisture from getting to the 2k primer underneath.
3 Is there an advantage to applying a 2K primer over the Epoxy primer.
Thanks for your insight X711
Old 01-19-2006, 09:23 PM
primer.
Answer to 1-- 2K surfacers are designed for filling and sand much easier than epoxy
2-- A sealer is used for a couple of reasons, to color the car with a shade that makes for better coverage, and to seal the substrate to the solvents from your topcoats don't get sucked in. Some 2K surfacers suck up solvent like a sponge.
3-- sandability
I usually don't use a sealer, the urethane surfacers I use for the final sanding work just fine. Epoxy does work well for a sealer but it shouldn't be applied very thick, needs plenty of flash time-overnight is best but not longer than it's recoat window unless you plan to sand and scuff. JMO
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Questions about Evercoat Feather Fill primer. Fordy8man Body - Exterior 16 02-05-2010 12:33 PM
Different primer questions Blazin88 Body - Exterior 10 08-02-2004 07:50 AM
Primer sealing questions ChrisMiddleron Body - Exterior 3 12-22-2003 01:47 PM
Epoxy primer questions asennad Body - Exterior 3 09-03-2003 08:12 AM
