primer reduction - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2004, 09:16 PM
primer reduction
i have a question, i bought this 2k primer surfacer ,and its high build, now it says I can double back and use it as a sealer .
the mixinging ratio is 4:1 for the surfacer, and the sealer, but then it says you have to reduce it 10 to 20 percent in order for you to use it as a sealer. my confusion is 10 to 20 percent, how do i measure that at.
Old 03-19-2004, 01:59 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
4 parts primer
1 part hardener
1.5 parts thinner
Later,
WEIMER
Old 03-20-2004, 12:29 PM
IT'S MY JOB...
It should be 4 parts sealer to 1 part hardener to 1 part reducer (at 20%). 1.5 parts reducer would be 30%. good luck
