When you pay $3 for a rattle can primer you get $3 worth of quality and about 3 weeks protection. If you like the way primer looks then pick a good urethane in the primer color you like and have your local auto paint dealer add a good helping of flattening agent and then spray the car with that. All the protection of a good quality paint and the color and flatness of primer all in one.
Centerline |
well i guess someone did not pay attention.....
MY question is does PRIMER SEALER keep out enviroments, not what paint looks like primer i know that stuff and plan to do this once i save enough for a decent job to be done. now can someone tell me if primer sealer keeps out the enviroments? please just thought of this but would a clear coat over it work? just thought of this but would a clear coat over it work? Last edited by 1Fast65Elky; 05-11-2004 at 12:53 AM. |
My point was that Duplicolor or any brand of rattle can primer/sealer really won't keep out the environment for very long. Your idea about using clear should work but I would do a test panel first to make sure the clear is compatible with the rattle can paint just to be safe. You'd be surprised what bad things can happen when two different paints don't react well together. Makes a real mess. Centerline |
You need a catalyzed urethane primer/sealer. PPG's K36 can be used as a sealer when the proper activator for sealer use is employed. A high quality catalyzed sealer will set you back a tidy sum, if all you are used to buying is rattle can junk.
Vince |
cool yah good idea doin a test panel.......hopefully it turns out okay , dunno when ill get around to it but sometime this month while its garaged.![]() thanks guys for the help |
