primer/sealer color under red? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2011, 06:35 AM
what is the best color for primer under solid bright red paint? would it be a good idea to try and get red tinted sealer under red paint? the paint will be 3 coats nason fulbase bc. color will be gm code 75. dupont code 5118
Old 04-19-2011, 09:03 AM
put up or shut up
Tint the sealer and it will turn the epoxy pink, which is close and a perfect start for easy coverage.
Old 04-19-2011, 09:44 AM
TucsonJay's Avatar
Some companies make a red sealer that looks about like red primer. I personally don't like to use a light colored sealer. If you have any areas with thin coverage, under direct sunlight, the light base will make them more obvious.
I use Sherwin Williams sealers, which come in gray... red... and tintable. Usually the tintable are too transparent for my liking.
Old 04-19-2011, 10:37 AM
white Epoxy!
Old 04-19-2011, 11:23 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
white under red .
Old 04-20-2011, 10:51 AM
Originally Posted by shine
white under red .
white? wow that is counter intuitive. can i assume that if white is best then the light grey of the primer/sealer should be ok or is it worth the effort to get someone to tint actual white?
Old 04-20-2011, 12:35 PM
your light grey will work just fine.
make sure you have enough base to go over it more than 3 times if need be.
Nason **** is like water and sometimes doesn't cover well
Old 04-20-2011, 12:54 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
White is counter intuative but it really makes red pop..just shoot to full coverage and roll it out into the sun and do a walk around before you shoot the clear and you will be fine..
Sam
color after sealer benchracer1 Body - Exterior 12 02-08-2010 04:01 PM
A test on primer color vs SOLID base color outcome Bee4Me Body - Exterior 9 10-14-2008 11:42 AM
Sealer color choice?? shad9876 Body - Exterior 6 06-18-2008 10:34 AM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 04:30 PM
Color of primer sealer kaw550 Body - Exterior 1 06-22-2006 10:14 PM
