Primer Sealer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2011, 08:35 PM
Ok, I'm using Finish 1 2k Urethane primer. I've already sprayed it on the hood I'm repairing. I have sanded the hood smooth, but I've got small but noticeable sand scratches that I'm afraid will show when I apply the basecoat. Will a Primer Sealer solve my problem since it may fill in the scratches???
What would you do??? I'm ready to paint, but I want the hood to look as good as possible. Any advice or help would be appreciated.
Old 02-28-2011, 08:50 PM
Mr Bolt, what grit paper did you use?
You might try sanding the scratches out with a lighter
grade of sandpaper, and wetsanding.
Old 02-28-2011, 08:51 PM
Underground's Avatar
Last journal entry: 54
What grit sandpaper did you finish with? Sealer will cover 320 grit scratches. If you are concerened, you can go finer to be sure.
Old 02-28-2011, 08:52 PM
You beet me to the submit button!
Old 02-28-2011, 09:01 PM
Great minds think alike.....
Old 02-28-2011, 09:24 PM
I usually wet sand with 400 grit, but this was going to be my final coat of primer so I wet sanded it smooth with 600. I guess some dirt somehow found it's way under my block. It was real smooth, and flat... until I noticed what looks like a few deep 120 grit scratches.
Old 02-28-2011, 11:50 PM
milo's Avatar
point on positive
It's been my experince when you second think they'll show they do.
Old 03-01-2011, 06:04 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
It's always better to sand the scratches smooth instead
of priming to fill them. Less chance of them shrinking back later on.
But to fill them, a coat of reduced epoxy as a sealer will take
care of most sand scratces.
Old 03-04-2011, 06:02 AM
deadbodyman's Avatar
Wiki Edits: 11
I would do both ...spray the epoxy as a sealer then wetsand it with 600 ,clean and paint....epoxy makes a very good sealer
Old 03-04-2011, 06:22 PM
Rag top bird's Avatar
Hot rods are still the king
you should no problem wet sanding with 600 and using a sealer
primer/sealer gun panelwagon62 Body - Exterior 9 04-30-2010 01:04 PM
Valspar DTM 2K Primer-Sealer Question danny_g Body - Exterior 4 09-02-2009 04:42 PM
Primer/Sealer Question bluesman123 Body - Exterior 3 08-27-2009 11:34 AM
lacqer primer over sealer primer jake henderson Body - Exterior 20 08-24-2008 09:12 AM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 04:30 PM
