It's a bad deal to apply Bondo on top of paint, it will eventually let go. The only primer that will not allow rust after a period of time is epoxy primer/sealer. Epoxy primer requires no clear coat and can be left as is for ever.
Vince |
soooooooo true, we drove our 40 chevy for about 10 yrs in Epoxy primer & NEVER had a problem w/it....joe |
is the expoxy primer any stronger then the normal primer? ive just noticed the normal stuff scratchs easy and stains when i touch it with my grease hands. if not.. is ther anything i can put over top for a more durable finish? thanks again
The problem is primer, any kind of primer, is not meant to "seal" the paint. It is still porous and will allow water, grease and whatever else that comes in contact with it to adhere and possibly soak into it. You really need to shoot some topcoat over the primer to seal it.
Mark |
There is primer, then there is epoxy primer, the two are not the same. Vince |
If you put primer on with RATTLE CANS you will need to remove it and do it correctly. Wet sand the whole car down with 360/400 wet or dry paper. Wash and dry it after that. Grind all rust down to bare metal, apply bondo where needed, finish off the bondo work, blow off the complete car, clean with Prep-Sol or other type of pre-cleaner, tape up the car and prime with epoxy primer.
Kevin |
Even epoxy primers need a top coat.
I used DP 90 black then used satin black lacquer on top. From what I was told the UV light is problem for the epoxy primers. There was a magazine article that talked about the different ways to get a suede black paint job. I no longer have a copy of the article. I recall they even talked about John Deere flat black paint. Don't think I would use it but they talked about it. One note some of the paint on my car has develop a polished look. Some of the polish came from the car cover others from washing it. Have fun! |
uhh hmm getting lots of differnt replys...
im going sand my whole car to bare metal then i want to bondo any dents and stuff. ok then i wash the car down good with a cleaner then primer the whole car with spray/rattle can(epoxy primer) and done?
Vince |
Fox....go back and read thru what was posted. You don't need to sand the whole car to bare metal. You DO NOT want to use rattle cans. Also take a peek into the Knowledge Base. There are some very fine articles on body work with step by step instructions. The main thing is to do it right the first time. It may take a little or a lot longer but it will still be less time than having to do it over.
Kevin |
The Reason i want to go to bare metal is all the pits/chips in the paint under the primer i got right now, all the bondo get it all off, i also noticed when i went to bare metal i did see some surfarce rust in a few places, and just do a nice clean job.
i just talked to a friend and he has a air compresser and is able to borrow a spray gun from work. |
