primered fenders - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2010, 08:01 AM
docs57's Avatar
primered fenders
How good is the black primer on new fenders, should I sand and primer or not?
Old 11-08-2010, 10:04 AM
Sick467's Avatar
Last journal entry: Wheels and Exhaust.
It definately needs to be sanded if you are shooting for a thourough and quality job. To many replacement panels have runs and paint flaws that you don't want showing up after you have painted it. And almost every one I've worked on needed some straightening by block and hammer or skim putty. Just a warning, these reprodution facilities tend to make parts in batches and I have found several that had light surface rust under thier primer from when the steel sat either prior to forming or prior to priming. I found this by prep sanding it with some 200 grit, next thing you know the black primer is popping off in places with rust underneath.
Sand it and keep your eye open for bubbles and runs.
Old 11-08-2010, 10:11 AM
kd5icr's Avatar
Camaro Guy All The Way!
I would agree, always re-sand and primer new parts. not only will you see if there is any surface rust but with a new coat of primer you will see any surface damage.
Old 11-08-2010, 07:17 PM
FRANKBULLITT's Avatar
We just repalaced a rear quarter panel on a 2010 ford and the new panel had runs in the e coat and pock marks best to always sand and primer.This was a $1200 panel .Yekes!
Old 11-08-2010, 07:32 PM
mitmaks's Avatar
Last journal entry: Grille
these aftermarket panels will almost always require some bodywork. They are so thin that they get damaged during shipping. You'll be getting a panel with a little ding here and there. You can run 80 grit sandpaper on D/A sander and then use primer surfacer. No need to strip it all the way down.
"Old School" Roadster Front Fenders rcrfly General Rodding Tech 26 06-04-2015 04:57 AM
Fitting fenders on a '32 327NUT General Rodding Tech 5 07-31-2009 10:41 AM
Superior Glass Works fiberglass fenders Rick4070 Body - Exterior 16 04-30-2008 02:51 PM
32 Ford Rear Fenders - Differences? LittleTruck Body - Exterior 2 02-10-2006 08:51 PM
will 88 Tbird fenders bolt on to 83 t Bird V Bird Body - Exterior 2 12-06-2003 09:18 PM
