I want to put a primered paint job on my 66 chevy pickup but do not want to worry about all the moisture primer draws.Is there a higher qaulity paint out there that looks like primer.
Old trick used by nostalgia rodders who want a durable suede paint job is to paint it with high quality color coat/clear coat system. Pait it first with the primer color then paint it with some coats of flat urethane clear.
a cheaper way to go may be to use a quality sealer, most are tintable and seal out moisture. they have a semigloss shine, the clear would be the preferred method though.
Lotta strange ideas out there nowadays.......
John Deere Blitz Black, it is a tractor paint and is really tough, but make sure to use John Deere thinner. I don't know if you can see very well, but that is what my car is.....good luck <img src="graemlins/evil.gif" border="0" alt="[evil]" />
p.s. you know it is good paint cause it is illegal in California [ August 30, 2002: Message edited by: drgnwgn289 ]</p> |
Trick from another world
In regards to the primer/topcoat issue:
I'm a musical horn repairman, and a lot of the older horns have whats called a satin silver plating. The silver isn't different, just the metal underneath. They sandblast it before they silver plate it. Same applies to a car. A light sandblasting will make anything put on top of it look "matte". Even glossy clearcoats look flat if applied this way. Just don't sand anything, no matter what. |
I'm wanting a flat black prime job . Body work done and primed and blocked once.Now I'm going to prime it one more time block that and spray it with a black base coat and leave it at that.At a later time I could fine sand the base and shoot more color then clear it. Will the base coat by it self protect the primer? Tom
| "Basic of Basics" Can I use "rattle can" paint on my car? | Centerline | Body - Exterior | 33 | 07-08-2011 12:33 PM |
| First paint job -- some dry spray.... | pmeisel | Body - Exterior | 4 | 07-07-2005 01:10 PM |
| Custom Paint Job? | Trippie-Hippie | Body - Exterior | 8 | 01-30-2005 03:22 PM |
| Full Bare Metal Paint Job | Toolish | Body - Exterior | 9 | 09-23-2004 05:13 PM |
| Looking for Paint Job ideas.... | Lonely Raven | Body - Exterior | 0 | 10-13-2003 09:06 PM |
