Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Primers??
Thread: Primers??
Old 11-01-2006, 06:41 PM
Centerline Centerline is offline
Wiki Edits: 49
The correct order is epoxy primer then filler then sanding primer then if needed sealer followed by finish coats.
