Primers - Cant Sand Substrate - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2013, 11:25 AM
So I’ve recently been busy building my 30x50 Shop…sheet rocking the interior now, but I recently came across and got some REALLY Nice & Heavy Duty Commercial/Industrial Cabinets with 6” Drawers..whole whack of them for free-99. Beautiful & Rugged Cabinets which I would like to use to make a “tool box wall” for lack of better terms, biggest problem is the color, they are all that “Office Equipment Tan” color. SOOOO, I’d like to paint em Red or Black…maybe both, issue here is the steel shell is “Textured” like a refrigerator, basically I see that and see un-sandable. The factory paint/powder coat is solid, no problem other than the color. Is there any primer which I can use without pre-sanding? Self Etch? Epoxy? Something else? I’d rather not dump crazy money into it…I’m thinkin Prime then Paint with Shopline Urethane Single Stage and enjoy them.
Thanks
Old 06-18-2013, 12:30 PM
Scuff with a red scuff pad and epoxy primer, it won't go anywhere.
Old 06-18-2013, 03:53 PM
Pats55's Avatar
Checked out AG 111 in red it's an anti-graffiti coating, tough as nails, can be applied with a roller since you're ready have a textured finish. As Brian noted scuff it up with the pad, wipe it with the corresponding thinner, and paint.A premeasured quart of red is less than 50 bucks.It also comes in different colors. Hope this helps.
Old 06-18-2013, 05:07 PM
Faith - Respect - Trust
Sorry Pat...I don't mean to disagree with what you posted but thinner isn't the product of choice...I'm glad you said corresponding because that would mean a pre cleaner...I'm thinking of the OP...thinner, as in lacquer thinner before painting often isn't a good idea. I hope I didn't offend, just trying to clarify.
Ray
Old 06-18-2013, 05:13 PM
Pats55's Avatar
Thanks Ray. Using an lacquer thinner with a urethane is usually a disaster. The solvent for the AG line this particular to that type of urethane. We usually encourage people to order the appropriate thinner or solvent for this type of coating . This is usually why its sold in kits Again thanks.
Old 06-18-2013, 05:49 PM
ogre's Avatar
the 'Duracell Project'
anything you paint them with will not be tough as nails
can't beat powder coat for tools boxes
you will have quite a bit in paint when your finished
but if you insist, do like martinsr suggests
we get a lot of powder coated electrical boxes to paint
we scuff with red using wax and grease as a lubricant/cleaner
you will need to prime then paint, paint will not stick to powder coat
Old 06-18-2013, 06:06 PM
Pats55's Avatar
is this tough enough?
Okay if you think that primer is required, good.would you suggest a urethane or epoxy primer?
Beginning in 1976, all through the mid-80’s, a fleet of 6500 NYCTA subway cars were coated with AG111 to combat the corrosion and graffiti problems. After 18 months of testing, AG111 was the only coating that could withstand repeated vigorous scrubbings and washings with heavy bristle brushes and strong solvents. Seven enclosed car wash facilities washed 400 cars a week. A solvent/alkali cleaner was sprayed on and allowed to soak 5-8 minutes. The car then passed through a wash machine where it was thoroughly scrubbed and put through three rinses.
AG111 cures to a hard mirror-like finish, which other paints cannot penetrate. According to the NYCTA spokesman, after the 18 month test, the subway cars retained their gloss and shine after each washing, and all traces of graffiti disappeared. “The cars looked like they had just been through the paint shop,” the spokesman said. Now a quart kit does 120 ft.² and it'll cover in one coat.
Old 06-19-2013, 05:59 AM
deadbodyman's Avatar
Wiki Edits: 11
I'd just clean W&G, scuff (red pad) spray an adheasion promoter (222 or bulldog) and shoot the dang paint..No primer.....
Old 06-19-2013, 06:18 AM
Pats55's Avatar
I agree, I don't think a primer is necessary. This stuff is pretty sticky. Yesterday I painted the floor plans on the 55 with the silver then the AG 2000 gloss black. The car is red, I should have painted the floor pan red.I have some wagon wheels that are powder coated and look like crap so today I'm going to put epoxy primer, urethane primer and AG 111 and see who sticks to what.The AG 2000 seems to have good adhesion also. Well I will know in a weeks time what the scoop is.
Old 06-19-2013, 07:02 AM
Good tips, I hadnt even considered an "alternative" paint like AG111... Satin Black & IH Red or JD Green are essentially what I'd be going for anyways. I was gonna use the leftover GM Fire Red Shopline Urethane I have at home. But if AG111 fits the bill, might just splurge on it and go with a 2 tone box.
I could have em blasted & powdered, but IMO I didnt want to dump that kind of money on it...might investigate it for the hell of it. These boxes are just for a few years..I'd really prefer a Macsimizer but until my wife goes back to work, wont happen.
Old 06-19-2013, 08:04 AM
I think you are right, primer is a serious overkill, we are talking about cabinets here not a hood that is going to be going down the highway at 70. Scuff it and get it painted.
Old 06-19-2013, 02:44 PM
Pats55's Avatar
Well if you should consider the AG 111 PM me and I will try to use my influence to get you taken care of. Nobody hates buying paint more than I do. Thanks for your consideration. Pat
substrate colors shine Body - Exterior 3 07-28-2009 08:32 PM
Which kind and where to get sand for my sand blaster daveh Garage - Tools 7 02-14-2008 02:04 PM
sanding substrate Frank123 Body - Exterior 2 01-30-2008 07:46 PM
is it necesary to sand epoxy primers prior to topcoating? Saddlebacks Body - Exterior 6 10-05-2006 06:50 PM
Wet sand, colour sand.... boofis Body - Exterior 9 05-25-2005 08:54 PM
