priming engine SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 06:08 PM
priming engine SBC
Hey guys question is: Is there any other way of priming my SBC before start up besides using that special oil pump priming tool that uses a drill?? The reason I ask is because I can't find anywhere close by that stocks those pump priming tools and they want $100 for one lol. Thanks for any input
Old 06-08-2008, 06:16 PM
Jmark's Avatar
If you have an old dist, you can grind off the teeth on the drive gear and then knock off the rotor plate so you can attach your drill. (that's what I have! LOL)
Another way is to put oil in some kind of tank that can be pressurized and run an oil line from the tank to the rear of the block were the sender is and then pump up the tank.
Old 06-08-2008, 06:24 PM
And the dist. shaft will fit in a standard drill, no modifications needed?
Old 06-08-2008, 06:26 PM
Jmark's Avatar
It should, unless you have a real tiny chuck. Mine fits a 3/8's drill. I did it all on my grinder, nothing fancy.
Old 06-08-2008, 07:16 PM
Thanks JMARK, as it turns out I found an old distributor kicking around and I quickly mocked this up. Take a look at the pic, hope it works!!
http://img.photobucket.com/albums/v7...zaman/tool.jpg
Old 06-08-2008, 07:42 PM
SSedan64's Avatar
You need to put the shaft back in the distributor housing or you will not get oil to both heads.
Old 06-08-2008, 07:47 PM
Jmark's Avatar
Yep, using only the shaft has caused many a bald head wondering why there is no pressure. LOL
Old 06-09-2008, 04:46 AM
Are you saying they scratched their hair off in bewilderment? LOL
Old 06-09-2008, 02:58 PM
techinspector1's Avatar
Wiki Edits: 326
The lower part of the distributor housing AND the priming tool will close off the part of the oil galley that is open to the pan. Without closing this galley off, you will get no oil flow to the passenger side rockers.
Why I have grown to hate the Small Block Chevy..... an essay Centerline Hotrodders' Lounge 316 02-08-2012 10:46 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
Priming my 388ci SBC strokey Engine 4 07-01-2007 12:04 PM
Engine Priming MI2600 Engine 1 08-18-2003 07:23 PM
Best gaskets set for SBC valve covers & engine Jag Daddy Engine 3 05-21-2003 05:47 PM
