Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Is priming the engine suppose to wear my drill out?
Old 08-18-2003, 05:57 AM
ded6elite's Avatar
ded6elite ded6elite is offline
i just primed my 289 windsor v8 2 weeks ago
if you are priming a high pressure oil pump it may wear your drill out i would advise filling your oil filter up bfore you try to prime as well this makes so you only have to pump through the engine
made that mistake with my dads 63 stingray corvette we had to fill his filter as well as pump all the way up to the rocker arms the drill was smoking on his but on myne it was fine
im doing a 68 coupe stang
