Priming metal in the winter, painting next summer? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-12-2002, 06:57 PM
stevesauto's Avatar
Post
steve here you need to use reaguler primer on all bare metal then i would use a good sealer primer over that if you did not sand the whole car you dont need to primer the painted parts till you get ready to paint the whole car then you will need to seal the whole car then paint
  #17 (permalink)
Old 11-14-2002, 03:42 PM
Post
I also have had good luck with red oxide primer in dry climates. Regular grey primers will rust in a few months requiring sanding (once again) down to bare metal. You can however get an etching primer that will not rust. They are fairly expensive costing wholesale around $90.00 per gallon. They also require a catalyst to kick off. There are some aerosol versions of etching primers available, Eastwoods has one, but they are extremely expensive at $20.00 a pop! The flat black primers look good but I have had no experiance with them. Doe's anyone know if the black primers hold up to the humidity without rusting?
Thanks,
Dave H.
  #18 (permalink)
Old 11-14-2002, 06:52 PM
Post
don't waste your time. Do it all at once. I don't care what primer you use, primer absorbs water, period!
  #19 (permalink)
Old 11-14-2002, 08:41 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
[quote]Originally posted by bondsman:
<strong>don't waste your time. Do it all at once. I don't care what primer you use, primer absorbs water, period!</strong><hr></blockquote>
I have used Martin Seniour Epoxy Primer and it will bead water for a while out in the weather. It does not absorb moisture and it is hard as a freakin rock. It is very good for bare metal.
Chris
  #20 (permalink)
Old 11-15-2002, 10:44 AM
tlambert's Avatar
Post
Here are two sites that may help answer questions that you have, but there are plenty more.
Here
