Priming a new engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2005, 10:14 AM
I've done it before, and had no problems, but I now have use of the internet. Is priming an oil pump with a long blade screwdriver OK if the oil comes up through pushrods. My problem is I started doing working on SBC when I was 14 and trying to dirt track. I didn't have a choice but to work on my on stuff. I didn't really know enough to work on my stuff, but i did anyway, and had pretty good luck as far as not tearing up stuff. To prime my engines, I just used screwdrivers until the oil pumped up out of the rear oil pressure gauge plug on the top rear of the engine. I never had any problem out of this. It's just the other day I was at an engine shop, and I saw them prime one with an high speed air tool for a while, and I know I can't do that by hand.
Old 09-06-2005, 10:22 AM
old distributor (less gear) or a moroso primer, spin the pump til you get pressure. Have seen people rotate the motor(by hand) while priming, however, can't comment as to the effectiveness of this
Old 09-06-2005, 11:06 AM
With all the assembly lube & cam lube in place & a full filter, is it really necessary?
Old 09-06-2005, 11:10 AM
Guess necessary is a determination to be made by the builder, however, I don't know any that do NOT prime before they light the motor off.
Old 09-06-2005, 11:11 AM
One builder has told me that priming at hi speed just washes away the assembly lube.
Old 09-06-2005, 11:19 AM
Bumpstick's Avatar
Hammer and a torch
I have never "primed" an engine before ever... I simply put Royal Purple assy lube in the oil pump (helps create a suction) and made sure the filter was full before install and with 2 rounds of the crank it has oil pressure... And as stated with good assembly lube in the bearing & cam/lifters and a properly setup fuel and ignition system (so it goes right to cam break in rpm 1500-1800) it should not have a problem unless something was done wrong to begin with... (100+ engines over 25 years) mild to wild...
Old 09-06-2005, 12:55 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Engines should be primed until oil starts flowing through every pushrod. You can buy a priming tool, make one from an old distributor, or you can buy a pressurized can of oil. I have never seen a pressurized jug other than on Horsepower TV.
Old 09-06-2005, 11:01 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I agree, then you know that oil is getting there ASAP when it starts.
I prime with a 14.4 volt battery drill or a 3/8 electric drill.... which spins the pump 4000 engine rpm.....
Which brings up another question. Why do people think a high volume oil pump sucks up too much horsepower to drive it...... if you can spin it 4000 engine rpm with a 1/4 hp electric drill and cold oil??? Does that make any sense to anyone but me?
Old 09-14-2005, 11:56 AM
You mentioning the cam break in rpm is that due to the floating cam in the 350
Henry
Old 09-14-2005, 12:14 PM
one reason for the higher RPM at first startup is to allow the rods to sling alot of oil on the lobes while the cam run in is taking place.
Old 09-14-2005, 02:07 PM
302 Z28's Avatar
[QUOTE=savman1] To prime my engines, I just used screwdrivers until the oil pumped up out of the rear oil pressure gauge plug on the top rear of the engine.QUOTE]
Your arms must be enormous
Vince
Old 09-14-2005, 04:08 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
[QUOTE=302/Z28]
Vince
haha. I would rather start my engine dry than try to prime it by hand.
I bought a Moroso primer and used my Dewalt drill. It made life easy.
Old 09-14-2005, 04:13 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have been primeing them for 40 yrs. I use an electric drill.
ENGINE BALANCING NAIRB Engine 22 01-23-2016 01:44 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
