Priming Oil Pump SBC 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2011, 07:20 PM
I just rebuilt my 350 motor, and when i am priming it oil only comes out on the drivers side head, and it only comes out of 5 of the rockers. It doesnt come out of any rockers on the other side. What could be the problem?
Old 11-29-2011, 08:17 PM
SSedan64's Avatar
What type Priming Tool are you using? If it doesn't have the 2 Lands at the bottom like the Distributor does, oil wont flow out to both sides of the Block, Heads.
Example Pics > http://www.google.com/search?hl=en&q...og&sa=N&tab=wi
Old 11-30-2011, 07:02 AM
Richiehd's Avatar
JS-70
You may also have to turn the motor over 1/4 turn at a time to fill all the oil galleries in addition to haveing the proper priming tool
Old 12-01-2011, 07:51 PM
well i rented a priming tool from autozone, and now oil comes out all of the rockers when priming it. But when the motor is running oil doesnt come out of any of them.
Oil Pump Priming Dino383 Engine 13 12-18-2010 11:05 PM
Priming oil pump DENCOUCH Engine 9 06-15-2008 08:21 AM
oil pump priming power Engine 8 06-21-2007 05:19 PM
Fuel Pump Not Priming Help!!!!!!!!!! 86camaro2.8l Engine 3 08-21-2006 10:56 AM
oil pump priming MardyMar Engine 1 05-03-2003 03:46 AM
