printed circuit board - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2012, 03:17 PM
I am wanting to connect a tach/clock combo into my 78 elk. Can I bolt a wire connector to the printed circuit board at the tach position? What type of metal should the connector be made of? Are there anything else I need to know to get it done?
Old 11-29-2012, 04:45 PM
Wiki Edits: 27
connector
brass or copper works best, years ago I worked at a GMC dealership and the service manager repaired a lot of printed circuits with a soldering gun, adding jumper wires.
The Following User Says Thank You to timothale For This Useful Post:
redsag 78 (11-29-2012)
Old 12-11-2012, 10:43 AM
Copper would work best. Brass tends to collect sulfur deposits sometimes in certain environments. Also, there’re some don’t for this as well, do not use iron or steel bolts. If you can use solder, that’s always the best option.
Old 12-11-2012, 12:01 PM
1971BB427's Avatar
When adding components or jumpers to a printed circuit board you should drill a small hole near the joint to hold the device or jumper first. If you simply bolt or solder to a printed circuit the weight of the lead or connector will eventually break the printed circuit material and fall off.
I drill a hole closely next to the area, then insert the end of a tinned wire, and solder it in place. Then I find a place as close as possible to tie the jumper off to keep it from hanging from the board. After that you can install a device to attach the tach lead to it like a single pin plug, or 1/4" insulated connector, so removal for service later is easy.
If the source you're tapping is for 12v. power, be sure it's large enough to provide power to the device and not burn up the circuit board.
Old 12-11-2012, 12:14 PM
sedan delivery's Avatar
clock part of combo
the clock will need a continuous 12volt feed to keep the clock running. something to think about
70 SS non gauge printed circuit board 70 SS Electrical 3 01-25-2011 11:53 AM
GM printed circuits 80PontiacWagon Electrical 1 09-08-2010 09:03 PM
circuit board trouble american muscle rulz Electrical 2 06-24-2007 11:17 AM
circuit board installation masman Electrical 7 03-30-2006 11:07 PM
1976 Corvette Tach Circuit Board schematic silvernblack Electrical 0 09-25-2003 08:01 PM
