Printoseal gasket question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2011, 11:50 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Does anyone know if the Fel-Pro 501SD gaskets have the print-o-seal on both sides of the gasket? Is it suggested to use a sealer on the other side? If it is only one side, why would the do this?
Old 01-17-2011, 01:31 PM
ericnova72's Avatar
More for Less Racer
No sealer used for this gasket, install it dry.
Printo-Seal side faces the head if it is only printed on one side, the head is what moves around more under heating and cooling.
Oil pan gasket question. Dajerseyrat Engine 5 12-19-2010 06:22 PM
Oil Pan Gasket Question. FastOrange Engine 5 06-14-2010 06:09 PM
Gasket Question seandiddy Engine 4 04-27-2010 01:20 PM
Fel-Pro Printoseal intake gaskets, which way? XNTRCI-T Engine 2 04-26-2009 06:52 PM
printoseal gasket question. TVR383 Engine 2 03-20-2004 02:46 PM
