PRO-CHARGING a "Classik" - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2010, 10:15 PM
chevorletc10's Avatar
"CLASSIK" Chevy
Well, I've been thinking... the ONLY way to achieve high HP is from a Super charger. I looked around and found the Vortec V-3 kit for my Small Block. its a "fair" price for something thats able to produce 700+ Hp.
QUESTION(s):
1) do i need to rebuild my engine SPECIFICALY for this (dish pistons, special cam & heads)?
2) will i be able to get it to make enought clearance with a STOCK hood?
3) will i be able to run power steering & have my altinator working all at once?
Old 11-17-2010, 10:21 PM
techinspector1's Avatar
Wiki Edits: 326
Why don't you share with us the information you have about the blower so we can help build on that.
Old 11-17-2010, 10:53 PM
ericnova72's Avatar
More for Less Racer
Short answer...
Question 1 - yes
Question 2 - I don't know without knowing the bracket configuration and vehicle it will be in, you're not giving us much info on things.
Question 3 - yes, if the blower mount is configured to clear both.
Old 11-17-2010, 10:55 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
With what you provided:
1. Yes
2. How would we know
3. How would we know
Line tech said, much more information needed!
(Hmm, we all think alike....)
Old 11-18-2010, 08:13 AM
Classik10's Avatar
CLASSIK Chevy
my account wont work (log on), so this is mine now. but its a 1970 Chevorlet Custom. it was a Sball block. from the top of the air clearner to the top of the hood os about 2-4.5" and from my altinator (right side) to the fender well is 6-9" across, plenty of depth also (Down).
Old 11-18-2010, 09:16 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You're wrong.
Old 11-18-2010, 09:48 PM
Classik10's Avatar
CLASSIK Chevy
IMO i think its the easiest way to do it...but of coarse im just 17....BUT i know somethings.... i have all these parts from jegs to make atleast 500 horses...
Old 11-19-2010, 09:55 PM
Classik10's Avatar
CLASSIK Chevy
Ok so heres the Specs to make 500hp (or so I think). **ALL from Jegs.com
CAM: Comp Cams "Xtreme Energy" Hydraulic Roller
CRANK: Eagle 383ci Stroker Kit @ 9.7:1 Compression w/ 64cc
HEADS: AFR 195cc Aluminum Street Cylinder Heads; 65cc Combustion @ 64cc Exaust
INTAKE: Edlebrock Performer RPM Manifold 1500-6500rpm
CARB: Holley 750cfm "Double Pumper" Mechanical secondaries
By what i found this should make around 500hp.
Old 11-20-2010, 04:47 AM
Do you already have those parts or is that just the parts that you are planning on using?
Shane
Old 11-20-2010, 09:38 AM
Classik10's Avatar
CLASSIK Chevy
I'm planing to use them, but i just dont have the money and hopefully they will all work right, 'cause i need it to be compression thats suitable for 91 Octance (i think 9.1:1- 9.5:1 is 91 or inbetween)
Is it possible to stroke a 400 more than it already is? stonedchihuahua Hotrodding Basics 18 11-10-2012 08:27 AM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
