Pro Comp 220cc vs Patriot 225cc vs Edelbrock E-210 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2011, 04:02 AM
Prostude's Avatar
I know this question has kind of been asked before
But I am looking for someone out there running a set of
Pro Comp Cncd 220 cc2.08 valve heads 68cc
Edelbrocks new E-210 heads 2.08 valve
or the Patriot 225cc heads
on a sbc 383 plus motor with a supercharger 6-71 etc.
Not looking for someone to chime in and say all these heads are junk?
There are plenty of people out there having very good luck with these heads.
The max I can spend is pretty much $1,000.00 on these heads
profilers are not in this category they are $1500.00
We have built some very competitive street strip motors in the last 25 years
from our 7 8 9 10 11 12 second cars.
There has to be someone out there running these particular heads
the Patriot heads out flow on paper
Dynos etc are great tools but I am looking for raw numbers at the strip with these heads.
I am not planning on spending more than $1,000.00 we already have motors that are running more than fast enough for us and this does not have to be a killer setup
just looking to run a little quicker with this build than before
Was running high 10's with gm smog heads on a 350 with a .480 hydraulic cam
any real 1/4 mile times would be greatly appreciated
There is one person on here that has been a great help with his 9.2 second 383 setup anyone else with a blown streetable sbc setup running a set of heads around this price range at the strip?
Old 01-08-2011, 04:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No cold hard facts/ET's to offer, but after doing some research the Patriot Freedom 225's seem like a head that I would look twice at- if budget was a big concern. 64cc chambers and 2.08" x 1.60" valves. About $900/pair.
They're not CNC'ed, so might not have the flow of the PC heads, but they seem to be assembled w/decent valves. Springs I'm not too sure about, and Jegs, at least, do not seem to sell them bare.
They should get the job done on a forced induction 383 cid engine, but the chambers may need opened up some.
Old 01-08-2011, 06:57 AM
Landshark928's Avatar
FrankenPorsche
Profiler 210 SBC heads are $1000 flat built with valves and springs. Check their website. The ones for $1500 are the Speier econo ported versions that flow a tad better. The stock profilers will easily flow what the others do with room for future porting.
I have the new Gen3 PC 210 CBC heads with a port match and pocket clean up. They seem very well built, however I have aftermarket valves and springs. I'm happy with the casting quality, no noticeable core shift. Pro comp is getting their act together. That being said, i do plan on upgrading to AFR Race 210s this year. With boost you should be more than fine.
Of the three listed, only The Eddy is USA made, something that will be chimed in on in
3...
2...
1...
Old 01-16-2011, 06:46 AM
Prostude's Avatar
3...
2...
1...
I was told the Profilers where closer to 1500.00 when i called them
I think maybe there website is outdated on the price part
I have seen examples of some great hp made with the procomps when they are ported properly.
Just was curious on the others
the edelbrocks where tested on a 383 and made 475hp
not very impressive
any how thanks for the info
Old 01-16-2011, 07:51 AM
How fast is fast enough?
There are a lot of other heads out there in that price range. Why not iron?
Old 01-16-2011, 08:07 AM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
I just bought a set of 210's pro-filers from Chad Speiers he is the man when it comes to cylinder heads and great head velocity.
Real reasonable aswell plus he will tailor the head to your needs check out his site his pricing is here aswell good luck!
http://www.speierracingheads.com/profilerecono.htm
By null at 2010-11-19
Old 01-16-2011, 09:58 AM
bentwings's Avatar
bentwings
I run a 6-71 on a 355 with Ed. Rpm heads which are even less than what you are asking. It runs just fine, not the fastest or baddest but it runs All the time, Every time.
Since I think you are looking at a budget build and not maximum hp so any of the lower priced aluminum heads will do the job. The job required is to remove heat from the chambers so you can run pump gas and flow a bit. Steel heads require lower compression ratio by about 1 point. I ran into a guy with last year with nearly the exact motor I have but with steel aftermkt heads and he had to run boost retard and reduced total advance and the best pump gas he could get just to run 5 psi boost.
I'd get 70 cc chambers for sure on any alum head and polished chambers won't hurt a bit on a blower motor.
3" exhaust with the biggest shortest tubes you can find is mandatory in my book.
I think I'd opt for 2.02 valves rather than the 2.08 as the valves are very close together and the seats are pretty thin to handle the heat that can come from the power of the blower.
Patriot 225cc SBC Heads? Prostude Engine 12 11-13-2010 07:34 PM
will edelbrock heads and comp cams sink watchdude1 Engine 4 06-02-2009 07:17 PM
pro comp and patriot heads. Icelander Engine 1 03-22-2008 11:12 AM
how does the pro comp 225cc sb ford heads perform? mustang joe Engine 3 07-08-2007 06:41 PM
Patriot Headers for a Tri-5 Stroker56 Engine 1 03-02-2006 08:55 PM
