Pro Comp Gear Drive, thoughts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2011, 01:48 AM
ComradeNorgren's Avatar
Have any of you guys used this gear drive on your sbc's? or anything else?
Old 08-07-2011, 11:24 AM
nothing but trouble!!!!!!!!! We installed 2 on 2 engines same time . both broke snap wrings on the idler gears blew 1 engine and saved the other when we changed oil and part of the snap wring was on the magnetic drain plug, also had two of the procomp rockers broke which we caught in time. Word of thought, any part that starts with pro I would leave alone. I dropped 3 valves and trashed a brand new set of there heads, were thinking there valve springs were junk. LIVE AND LEARN .
Old 08-07-2011, 11:39 AM
bigalow's Avatar
I've been running a Pete Jackson gear drive on sustained high rpm highway cruisin for 2300 miles and so far so good!!!
There were three schools of thought:
Go chain a gear drive will fall apart on the street?
My roller rockers will loosen up all the time?
A few people said the pete jackson is a good unit and will hold up fine?
Old 08-07-2011, 11:57 AM
sqzbox's Avatar
My pipes are my music
Pro comp spiral 10.5 mm cables work pretty good. No moving parts.
Old 08-07-2011, 12:15 PM
That is probably true, just don't use anything important that has procomp on it. As for gear drive I wouldn't run one on the street or for race of any brand.These were on strictly drag cars
Old 08-07-2011, 12:49 PM
Thats what i was afraid of. haha. i just bought a pro comp gear drive. So i guess i'll be writing return to sender on that package. Ah well. thanks for the info guys. I can't think of anything worse than having my timing gears fail.
Old 08-07-2011, 10:23 PM
bentwings's Avatar
bentwings
Biglo said it....
I have 16k miles on my gear drive, roller rockers, High vol/pres oil pump and a few other items rumored to be not streetable.....oh yes 8k on the last oil change and analysis was very good.
Roller rocker have not been adjusted in at least 12k miles. No stud guides however.
Old 08-07-2011, 10:34 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Can't speak for the Pro Comp product but I installed a Pete Jackson gear drive several years ago. I didn't have any driveability issues other than the fact that the noise drove me nuts. I didn't think I was going to like it but installed it anyway. Be sure you're going to be ok with the way it sounds before you install it.
Old 08-07-2011, 10:44 PM
bentwings's Avatar
bentwings
2X on Pro Comp
Old 08-07-2011, 11:14 PM
bigalow's Avatar
I installed the extra noisy PJ drive and i love the sound otherwise I would just go with the boring old trusty chain roller
Old 08-07-2011, 11:38 PM
bentwings's Avatar
bentwings
Mine wasn't the real noisy one but you could definitely hear it. The blower and drive made noise too and drownded out the gear drive . Now with lots of miles the whole thing has quieted down....maybe I'm just used to it.
Old 08-08-2011, 01:17 AM
I do like the noise, i have a cloyes noisy gear drive in my 64 bel air. Just was hoping to get a gear drive for half the price. So you have a pro comp gear drive BentWings? Would you guys still use it? Could it possibly be THAT bad of a gear drive?
Old 08-08-2011, 07:22 AM
bentwings's Avatar
bentwings
No not PC. Sorry to mislead you. Mine is Pete Jackson.
Old 08-08-2011, 07:26 AM
I couldnt even get a pro comp fuel pump to run more than 30 seconds before it failed.
Old 08-08-2011, 07:40 AM
cool rockin daddy's Avatar
You get what you pay for. I never skimp on tools, and I never, never skimp on the parts that go on my car. Just curious, where would you feel that is okay to put a cheap part on your car besides the cam drive? Suspension bolts? Seat belts? Connecting rods? Maybe windshield washer fluid, that's the only one I can think of. C'mon.
The Following User Says Thank You to cool rockin daddy For This Useful Post:
Bow.Tie (10-08-2013)
Comp Cams Belt Drive rector_racing Hotrodding Basics 0 05-12-2011 02:15 PM
Comp Cams belt drive / damper fitment SoCalJim Engine 2 07-31-2009 07:40 PM
No reverse gear and slippage in Drive 2nd gear. jadejoky28 Transmission - Rearend 14 04-09-2009 12:49 PM
Thoughts - Comp Nostalgia Plus N+LS6 Cam dsolomon Engine 1 02-26-2008 01:39 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 09:47 PM
