Pro Comp Intake 3000-7000 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 09:44 PM
I have a 388 stroker with 6' rods floating piston pins Keith black pistons I wanted to get a 294 comp cam rpm 2800 -7000 and my intake is a square bore high-rise pro comp intake 3000-7000 rpm..No daily driver just track and a short cruse to the park...Will this cam work good for me??I know i need a 3300 stall and rear end gears..how much horse power should I make?
Old 02-20-2012, 10:36 PM
I for got to add the cylinder heads.I have 2.02 and 1.60 valve and intake port volume 200 cc and combustion 64cc aluminum heads. The lift on the extreme comp cam is 519/523 only with 1.5 rockers I have 1.6 rockers..comp cam 294/306.with only 150 shot of nitrous.....cam#12-254-3
Question on Pro Comp Heads on SBC and intake matching y2k600f4 Engine 20 10-10-2012 07:14 AM
P-Comp Intake? frodin1 Engine 2 08-26-2010 06:43 PM
Satajet NR2000 vs 3000 b / 3000 hvlp / 3000 rp Top Secret Body - Exterior 1 05-22-2009 09:34 AM
How to rev a 350 to 7000 HJCHEVY400 Engine 18 06-16-2004 09:33 AM
