pro form carb conversion for blower - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2010, 08:57 PM
i have a holley 750 double pumper with pro form main body and metering plates. just purchased a weiand 177 blower and need to convert the carb. anyone have any pics or info on how to do this. called pro form but they sent me to quick fuel. thanks
Old 12-02-2010, 09:07 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
A single search here for simply 'blower carb' just brought 200 entries, different search criteria will find more.
There's a lot of information in our database, surely there's something there for you, give it a try.
Old 12-02-2010, 09:11 PM
just getting familiar with site. tried searching before and kept getting sent to diffrent sites. just thought now that im on the site somebody might have a little more info. but thanks for the tip.
Old 12-03-2010, 07:08 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm talking about the search feature here on the HRB, not your browser.
Old 12-03-2010, 10:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A couple thoughts...
That carb is going to limit the boost you can use to around 5 psi. Was the carb calibrated for a good fuel delivery curve before the blower came along?
  • The fuel pump needs to be capable of supplying the engine w/enough volume at 5 psi and WOT to avoid lean out. An electric pump would be my preference. Best to use at least 3/8" fuel lines from the tank. More on pumps and regulators HERE.
  • Boost referencing the PV on a Proform throttle plate is covered HERE. Modifying a Holley throttle plate is shown HERE. Another option is to block the PV w/a plug made for the purpose and jet the 2'ndaries larger by ~8 sizes (varies by case).
  • It may need some more accelerator pump volume and/or duration.
  • Might want to use 0.110" needles and seats.
  • The Summit 1103 or 1105 cam works well w/this size blower, or so I've read.
  • Don't forget to modify the ignition timing curve to work w/the blower. The Holley Supercharger Installation Instructions and Technical Manual is HERE. It has the boost chart, pulley sizes, timing recommendations, tensioner and other part numbers, etc., for your set-up.
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Convert carb. Jim69Mustang Engine 1 02-11-2004 11:48 AM
Carb to fuel injection conversion virgil reed Engine 5 09-25-2003 03:14 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
TBI conversion to Carb Seon Engine 0 10-15-2002 03:20 PM
