pro welders, I've got a challenge for you to firgure out - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 01-11-2013, 09:17 PM
or buy the adapter for your mig that Eastwood sells, turns it into a stud gun
  #62 (permalink)
Old 01-12-2013, 05:12 AM
deadbodyman's Avatar
Wiki Edits: 11
Originally Posted by slowrider16 View Post
could you not just cut a peice of wire to whatever length...or heck just get the studs that the stud gun uses...and weld it to the panel?
cut the wire and weld it to the panel???......now theres an idea and so simple,it just might work..mabee I've been over thinking this thing.
  #63 (permalink)
Old 01-13-2013, 09:31 PM
This is not very elegant, but disconnect the ground clamp from the work piece. When you pull the trigger the wire spool will run without any current flowing to the work piece.
  #64 (permalink)
Old 01-14-2013, 06:10 AM
Wiki Edits: 11
I tried that (while welding) and it works once in a while about 2 out of 10 trys. its very hard to do...
I did try cutting some wire and welding it to the metal and this worked so before I go any farther I'll get my fulcrum puller finshed (homemade)and see if the wire will actually be strong enough to pull a dent...I'm also working on a stud holding attatchmant for the tip so I can weld studs on from my stud welder...This'll work well for the bigger dents...
Anyone up for a Challenge? ethn_bert General Rodding Tech 34 06-27-2010 02:29 PM
i hate having to spoon feed car guys that cant firgure out anything themselves ... lowROLLERchevy Hotrodders' Lounge 17 09-26-2007 03:24 PM
Redneck Challenge wts Hotrodders' Lounge 0 04-01-2005 12:48 PM
Heres a little challenge Bluepen Engine 5 10-09-2003 05:22 PM
Heres a challenge jeff germano Engine 5 03-18-2003 03:24 PM
