problem with 350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2002, 09:38 AM
stfinney's Avatar
Arrow problem with 350 sbc
I have a truck with a 350sbc in it and some mornings (not all mornings) it idles good while warming up and then it spits and sputters. I can give it a little gas and it runs fine, but then idling it runs roughh and sometimes shuts off. I can then restart it and it may run fine. It's wierd! Any ideas what it could be? I was thinking maybe the carb, but I'm not sure.
It is a 1980 350 sbc with an Edelbrock 600cfm catb, stock heads, Weiand aluminum intake. 278 duration cam with .467 lift and 222@50, Accel HEI Super Coil and 8mm wires with Accel shorty header plugs. The lower half of the motor is all stock.
Thanks for any help!
Old 12-15-2002, 10:25 AM
Post
Edelbrock 600's come with a electric choke and the less expensive ones do not. Which do you have?
If it is the one without a choke..... the temperature (outside) could be the reason......
Old 12-15-2002, 01:33 PM
stfinney's Avatar
Post
It is the one without a choke. It never did it before, it just started doing it. <img src="graemlins/boxing.gif" border="0" alt="[boxing]" />
Old 12-15-2002, 01:52 PM
Don Meyer's Avatar
Post
Edelbrock/carter are good carbs but I have heard they have had problems w/flash. A pc. of flash might have broken off & is causing you trouble.....Don
Old 12-15-2002, 02:16 PM
Biggarmike's Avatar
Chief Procrastinator
Post
EGR or Non-EGR intake? cold weather can make them stick and act goofy too. That can really hose up your engine's dropping back to idle from partial throttle.
Old 12-15-2002, 04:10 PM
stfinney's Avatar
Post
It has the EGR port, but I am not using it. I am going to buy another intake that doesn't have the EGR though.
Old 12-15-2002, 04:45 PM
Post
[quote]Originally posted by stfinney:
<strong>It is the one without a choke. It never did it before, it just started doing it. <img src="graemlins/boxing.gif" border="0" alt="[boxing]" /> </strong><hr></blockquote>
I do not know how cold it is in your part of TN but it is getting colder (winter time). When you restart it, more warmth is in the motor.
I have the same situation with the 750 Edelbrock on my 32 Roadster. Never a problem in the summer. When the temperature drops, it needs a choke!
Without a top...see the photo.... I do not drive it much when it is cold!
