Problem after tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2005, 05:41 PM
lt1bbody's Avatar
Last journal entry: The '85 Monte Carlo
I blew the pump out on my th350 in my 85 Monte. I swapped a tranny out of the 82 I have the tranny is a th250. The problem I have is that the car vibrates a lot when I speed up. The car also feels like it jerks forward when stopped at stop signs. The car doesn't have the power it use to either. When I did the swap I had to pull the motor and trans because the crossmember was welded in place by the guy I bought it from. Could I have a problem with spark or is it the tranny? I don't think it is fuel because I changed the accel. pump to see if it would help.
engine problem after trans swap lt1bbody Engine 2 07-25-2005 01:01 PM
S10.....tranny swap. poncho62 Transmission - Rearend 5 03-26-2005 05:33 PM
TRANny & O/D light problem on 96 mercury mystique grover805 Transmission - Rearend 9 08-24-2004 11:59 PM
Tranny Problem arch Transmission - Rearend 7 07-27-2004 10:34 PM
1995 Z28 Tranny Swap mael64 Engine 0 12-23-2002 05:50 PM
