problem on back up - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2008, 08:43 PM
problem on back up
got a ranger for a deal .
told tranny going out .
it's a 5 speed over drive ranger .
i know brake questionnaire form so here goe's -----
drive truck ,no noises , no problems going forward .
backing up though , it starts locking up and jumping and lunching effect when your on and off the clutch after 30 feet.
if you apply clutch the thing stops rolling ,dead in it's tracks like you had pull parking brake .
but if you don't push in clutch and apply light gas it keeps backing up .
if tranny was bad it would make noises and grind ,but there's no noises at all.
goes 70 mph forward like it should ,but backing up
could the brake shoes be applying cause ????
shoes maybe backward ,long on front and short on back ????
anybody had this problem ?
only in reverse
Old 01-18-2008, 09:04 PM
poncho62's Avatar
Wiki Edits: 5
Or your brake hold down spring broke and the shoes are binding.
Pull the back drums off and check.
Ontario Rodders
Old 01-19-2008, 05:13 PM
problem on back up
WELL I CHECKED BRAKES AND THERE GOOD
pulled drive shaft from rear .
it's not real free on turning even with tires off .
you can spin one side and other side turns opposite but has a tight spot and i didn't see the yoke end turning at all , this with drive shaft out .
it has the ring gear with a small gear around it for ????
maybe anti locking brake crap , or clicker posi , i don't know .
waiting on grease to drain , to check ring and pinion.
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 12 07-19-2007 08:07 PM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 07:29 AM
Problem: Steering Rack? horvath Suspension - Brakes - Steering 64 06-15-2005 08:11 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
