Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problem batch loading larger images
Old 03-23-2005, 07:16 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Whew, that actually makes me feel a little better (or maybe worse).
Here are a couple more clues for you Jon. Don't know if they will help.
When I get the error with Firefox, it generates this url:
chrome://global/content/netError.xhtml?e=netReset&u=http%3A//hotrodders.com/forums/journal.php%3Fjournalid%3D17166%26action%3Daddentr y&d=The%20document%20contains%20no%20data.
When I get the error with IE, it generates the following error message, Note esp. the last line regarding not finding the server or DNS.
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
BTW, it I follow the IE directions and click the refresh button, I get sent back to the opening, main Journal Page. This also happens if I click the "back" button.
This morning I tried to do the upload using Netscape 7.1 and got the error message:
Alert: The document contains No Data.
Always learning...and sharing what I've learned.
