Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problem batch loading larger images
Old 03-23-2005, 12:28 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Just tried again using Firefox and got the same error.
BTW, I don't think it's a "timing out" problem, at least not a typical one. The error message comes up within a couple seconds of hitting the upload button.
On the other hand, when I use IE as my browser, the error occurs differently. With IE it appears at my end that the upload is taking place. After hitting the upload button the Windows "flag" waves and the progress box shows progress (although, as I recall, I don't think it makes it all the way to the end) Then at the very end, when I'd normally be redirected back to my journal to see the new entry, the screen is just while. If I click the url in the address line I can then read the error message (which I sent you in my prior post).
Always learning...and sharing what I've learned.
