Problem with car not wanting to stay running at idle without feathering the throttle - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2012, 07:55 PM
sbc 327, 195 afr heads, 2.05 1.6 valves, 750 holley carb, msd 6al ignition and pro billet dist, cam is comp cams xe284 dur-int 284 exh-296, and 1.6 ratio rockers. this car is used for racing only, no street use
my problem is i cant seem to get the motor to idle without feathering the gas at about 1000-1200 or it will die, can rev motor and runs fine except for at idle. anyone have any suggestions i could try out? Thanks!
Old 03-11-2012, 08:12 PM
how low are you trying to get it to idle?
Old 03-11-2012, 08:16 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Are the throttle blades closing too far covering the idle slots? Dirt clogging the idle circuits? Vacuum leak? Is it loading up or lean?
Semper Fi
Old 03-11-2012, 08:22 PM
im just trying to get it to idle period. the throttle blades looked fine when the carb went on but could use a second look anyways, and it doesn't seem to be loading up. could it have to do with my mixture screws?
Old 03-12-2012, 08:36 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Adjust A/F mixture screws a back out a little.
Old 03-12-2012, 09:00 AM
sqzbox's Avatar
My pipes are my music
A vacuum gauge will help a lot setting it at maximum vacuum.
Old 03-12-2012, 06:51 PM
the dist is set up for 36 at idle already, but since i dropped the new heads on i cant get it to idle to set my timing back at 18 on idle. car has a 3500 stall already.
Old 03-12-2012, 07:13 PM
topwrench's Avatar
Last journal entry: fish carb
Originally Posted by F-BIRD'88
You need a lot more initial advance at idle .
Lock out the distributor mechanical advance curve
and set the locked timing to 36deg BTDC at idle.
Get a 4.5" rated power valve.
get a 8" 9" 4000++ stall converter.
This cam will not work with a stock converter
This cam will not work with a stock out of the box distributor curve.
Needs a minimum of 26deg timing at idle.
runs and idles great with locked out timing.
This is "ditto"for me!
why did u back the timing off to 18?
Check the secondary opening setting i think you also may be adjusting primary idling too much to get it to idle
Old 03-12-2012, 07:51 PM
just the initial idle timing needs to be at 18, not total timing..sorry..what do you mean by checking the sec open setting
Old 03-13-2012, 06:33 AM
he already said he has a 3500 stall converter already. i dont consider that to be stock
Old 03-13-2012, 07:11 PM
I was talking with a friend on what he thought and he mentioned the idea of the valves being set to tight. Think this could be causing my idle issues?
Old 03-14-2012, 03:11 PM
backing the valves off a hair didnt change anything...im cant find a vacuum leak anywhere so im putting that to the side for right now...the carb doesnt have a power valve...the guy that builds them around here says that if you dont run a power valve that you generally run them about 10 sizes bigger on jets...i believe the primarys are jetted at 80 and sec at 78...id have to go out and look but im pretty sure thats what it is
Old 03-14-2012, 06:58 PM
i also cant get a reading on my idle for timing right now since it wont stay running at idle...tried moving changing timing both ways a hair off dist but makes it hard to start on advance and worse on retard
Old 03-15-2012, 03:46 PM
topwrench's Avatar
Listen to F bird!
Hes rite,Im runnin a 750 Holley mech sec on a built 355
73 on primaries 80 on secondaries.4.5 power valve 25* initial 10* mech,5vac,but my cam is smaller than yours.
You need a power valve do not ever remove a power valve unless you are runnin at a relatively constant speed I.E. long track, round track as in stock car.Or dragster where u come off line at high revs with a rev limiter n trans brake and keep the rpms high
Been there done that! put the power valve back on,lock out timing as F bird said.
Man why would anybody take a power valve off!
Some Chevys came out of the factory with 2,1 for pri n 1 for sec.
Your motor will lean out big time without one during acceleration
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
amc 304 won't stay running redneckhotrods Engine 12 03-07-2010 02:29 PM
will not stay running punched350stepside73 Engine 3 02-28-2010 07:50 AM
engine wont idle, or stay running lowandloud91 Engine 16 08-10-2009 12:27 PM
Car Won't Stay Running MyMalibu Engine 9 02-27-2008 08:16 PM
