Problem converting a 1972 Camaro to an internal regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2008, 03:10 PM
I have connected the blue and brown wires and the white and red together at the old regulator plug. At the alt I connected the blue wire to #1 and the white wire to #2 terminals. The car will run just fine for a few seconds and then begins to run rough. I can disconnect the jumper wire for the red and white wires at the old regulator plug and it runs fine but I 'm no longer charging.
Any ideas!
Electrical Short, Possible Voltage Regulator Claude Electrical 2 06-21-2003 01:13 AM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
1984 Camaro headlight problem brian400ex Electrical 4 03-07-2003 04:06 PM
69' camaro master cly. problem josh7681 Suspension - Brakes - Steering 3 12-31-2002 04:40 AM
camaro transmision problem headfukt Transmission - Rearend 2 04-09-2002 12:11 AM
