problem with ford transmission ,please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2003, 02:42 AM
mikeweyman's Avatar
Last journal entry: 2 years later
Unhappy problem with ford transmission ,please help
hi folks, maybe you can help me with a problem i cant get my head around.i just bought a 93 ford extend a cab,302 efi with a tow package, auto tranny and posi track. i dont know what tranny it has ,but the pan is big enough to wash a baby in. Anyway . i've been having problems with hard shifting, and upon re-accelleration a slight spin before it catches.i checked the fuses the other day , trying to get the speedo working. the same fuse has transmission written on it too.i replaced the missing fuse.the temp gauge and speedometer worked fine, but as soon as you pull away it shifts to second then third, within 50 feet,then of course it bogs out.on the same note, the battery ,fuel ,and oil pressure gauges register high. when you pull the fuse, all returns to normal.if it has parts that move, i can fix it,but this i can't so please help if you can. mike <img src="graemlins/pain.gif" border="0" alt="[pain]" />
"BE ALERT" the world needs more lerts
Old 05-23-2003, 06:17 AM
4 Jaw Chuck's Avatar
Post
Any codes from the computer Mike?
— Han Solo
Old 05-23-2003, 02:41 PM
mikeweyman's Avatar
Post
i only know how to decode a dodge on off on off on off on, but that didnt work. you know the way for a ford
Old 05-24-2003, 02:00 PM
Post
You need a code reader or a scanner if you really want to see what is going on with the electronics.
— Han Solo
Old 05-24-2003, 02:47 PM
mikeweyman's Avatar
Post
should i go to a ford dealer and pay the big bucks or will the one at my friends shop do it?
Old 05-24-2003, 02:48 PM
mikeweyman's Avatar
Post
Old 05-24-2003, 07:02 PM
New Member
Smile
As long as he has the right cartrage to read that particular vehicle and knows how to read them your friend should be able to do it.........
