Problem FOUND ! Demon carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2004, 09:15 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Some may know, I was having problems with my new motor for the last 4 months. I went from a Road Jr. to the Crate Demon when I found out from tech support that I HAD to use the Crate Demon. (Summit left me hanging there! Sold me the motor and carb at the same time, and wouldn't take the Raod jr back when I found it was the wrong one to use)
I threw a Crate Demon carb (Vacuum secondaries) on my 330hp/350 , and was driving myself NUTS for the last two months. Completely lost all faith in my tuning abilities (minimal , at best). The car would backfire intermittantly under hard acceleration. I took the thing apart NUMBEROUS times. Finally found the mother that was causing the problems. The rod that pushes the secondaries closed on deceleration, was slightly tweaked. When you floor it, it was dragging the secondaries open a little, and they would close right away. Never noticed it before. A little tweak to the rod, so it didn't bind, and we are backfire free !!!! This was driving me nuts! Also checked my Road Demon Jr., it did the same thing! NICE !! 2 NEW carbs, both with the exact same problem ! Wonder if I REALLY needed the Crate Demon???
Now, I can do some fine tuning, finally !
Old 08-17-2004, 09:27 AM
figure8's Avatar
I don't see why the road Demon Jr. wouldn't have worked just fine. I have an Edelbrock 1406 600 cfm on my 330 hp 350 and it works fine out of the box. At the most the road demon jr. would require some very minor tuning. Why are these Carbs so limited to what they will work on when Edelbrock & Holly seem to work fine on just about any engine? Mabe someone can answer this question. Phil
Old 08-17-2004, 10:41 AM
GoneNova/406's Avatar
there's a guy that lives two blocks from me that has a drag car falcon with a 460.his wife started working at jegs new wharehouse a couple of yrs. ago and when the demon carbs. first came out i remember him telling me that they had a lot of trouble with them.returns.from everything that i've been seeing in the car magazines though i just assumed they had gotten it all straightened out.thats good info to have cause i've been thinking about getting one in the future.
Old 08-17-2004, 01:22 PM
I was told that the reason the Road Jr wouldn't work, was because of the exhaust duration. You'd think that they would at least educate the sellers like Summit and Jegs. Or print a disclaimer of some sort. Either way, neither Summit and Grant would take the Jr back. Kind of sucks, because anything I run will have big duration. The CFM is more than plenty. Its the low signal strength that the duration produces will not allow the correct idle mixture.
Old 08-17-2004, 02:06 PM
figure8's Avatar
now that you have figured out the problem have you ever considered trying the road demon jr. again. I bet you are right and it would work OK with the linkage fixed. Let us know what happens if you try it. Phil
