Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Problem hooking up Dakota Digital Cruise Control
Old 09-08-2012, 07:06 AM
roger1's Avatar
roger1 roger1 is offline
I've got a '55 Chevy Bel Air with a Ramjet 350 crate motor running the stock Mefi4a ECU and a new Tremec T56 Magnum aftermarket 6-speed transmission. The transmission has a 2 wire inductive VSS and I have a VDO electric speedometer that is working perfectly. After calibration it is reporting that I have 32,380 pulses per mile.
I've got my Dakota Digital (DD) cruise control (made by Rostra) installed and started wiring it up and ran into a snag.
The DD cruise wiring only has one wire for a VSS hookup and the inductive VSS sensor coming from my T56 Magnum has 2 wires. And btw, I hooked an ohm meter up to the 2 wires on my VSS and neither is a ground. The inductive VSS sensor must generate an AC voltage to the 2 wires.
It appears the DD unit VSS wire is designed to come off the ECM and not directly from a VSS sensor like I have. (My Ramjet 350 ECM doesn't use a VSS signal so I have no VSS out from it.) The DD instructions say it needs one wire from an ECM or one of the 3 wires if using a 3 wire VSS sensor on the transmission. I did get a comment on another forum where someone had a DD unit that indeed does work with his 3 wire hall-effect VSS sensor.
Is there a converter that I can use to generate the signal the DD unit needs?
I sure don't want to have to put a magnet kit on the car (yuck).
Anybody have some suggestions on a solution? I sure would appreciate it.
