problem installing front sway bar 40 ford. - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-25-2007, 07:10 AM
Hello And Good Morning. I have a 1940 Ford five inch section, nice car with a ton of work done to it. my big problem was front end sway on highway speeds, and in windy conditions. so i decided it must be the absence of a sway bar(front) so i got the kit from Ches engineering. problem started with sway bar hitting the bottom water outlet on radiator. Can't raise the radiator up the the two plus inch i need for clearance(remember 5 inch section with pancake hood) hood doesn't clear top of radiator.big question is can i space the sway bar bushing plates the two plus inches down where they connect to the frame with out messing up front end geometry and function ? Any help with this problem, or other ideas would be appreciated. Thanks Egop8
Old 03-25-2007, 07:19 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
This is the Introduction forum....best to ask in the Steering and Suspension forum.
Old 03-25-2007, 07:36 AM
Suspension Area.
Sorry about the incorrect posting. dont know how to get their, first timer---Help please---.
Old 03-25-2007, 08:05 AM
classic cruzer's Avatar
Click on hotrodders bullitin board and then suspension and brakes and your there.
I'am a little confused about your problem unless your rad is mounted forward of your frame, but I dont see how that could be. I mounted mine on the forward side of the frame and up over tie rods around the radiator. I have a mustang ll front suspension so maybe thats the difference.
Sway Bar Question Retiredrich Suspension - Brakes - Steering 3 03-01-2007 07:02 PM
32 ford frame width at front axle centerline Dirty Steve Hotrodding Basics 4 05-15-2006 07:40 AM
'93 Taurus front sway bar Question. schnitz Suspension - Brakes - Steering 24 01-02-2006 11:13 AM
65 Belair Sway bar question sabino56 Suspension - Brakes - Steering 11 12-26-2005 08:22 PM
1973 Mustang front sway bar question? Steve-0321 Suspension - Brakes - Steering 1 12-11-2005 11:12 AM
