We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 06-30-2005, 05:15 PM
airman_turtle's Avatar
airman_turtle airman_turtle is offline
Problem installing line lock
i picked up a B&M line lock, and i seem to have come across a problem.
The holes on the line lock are 1/8 and the hole on the master cylinder are 9/16.
I found a fitting that is 9/16 male to a 1/8 female and this with cover the connection of the line lock to the master cylinder.
Heres where the problem come in. I went all over town, but could not find the other one i needed...a 1/8 male to 9/16 female to cover the connection of the front brakes to the line lock. I cant even find one on summit.
What should i do?
Old 06-30-2005, 07:49 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Rob Keller's barnstar
Wiki editor
Last wiki edit: How to clean glass
Wiki Edits: 38
what are we working on?
sr66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 07-02-2005, 08:38 AM
it is a 1987 monte carlo ss, but i figured it out, thanks.
Old 07-04-2005, 10:35 AM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
glad you figured it out.
I have the same car. For future reference; this is how I did mine. I was able to use the original brake lines by disconnecting them from the proportioning valve and bending them up near the shock mount. Then tied them together with a splitter. Then I ran a line from the splitter to my line lock and another from the line lock to the proportioning valve. See pic.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Problem installing line lock"
Engine stalling problem JamesRS Engine 3 01-30-2006 11:22 AM
Ignition Problem malibuman66 Electrical 17 01-24-2006 01:05 AM
Ford spring lock fuel line coupling question dirtlmfan Engine 5 07-09-2003 10:52 AM
Ignition problem??? Centerline Engine 2 06-29-2002 05:53 AM
SBC Cooling bypass line question HotRodF100 Engine 2 06-15-2002 06:50 PM
